nitrous outlet pro max controller question
Old Apr 29, 2021 | 02:16 PM
sniffin94's Avatar
Default nitrous outlet pro max controller question
Is there a way to run the pro max controller to a tablet?
Old Apr 29, 2021 | 04:45 PM
brandon@nitrousoutlet's Avatar
It will, if your tablet uses the full version of Windows 10. Otherwise, it will not.
Old Apr 30, 2021 | 07:03 AM
sniffin94's Avatar
Thanks for the reply Brandon. Will the home screen show the same display as what is on the first page on the install manual? Ive been thinking about re-doing my setup, adding the pro max, mounting a tablet in place of the stereo and using the 4 buttons in the factory location just above for arming, remote opener, purge and heater. Anyone done this?
Old Apr 30, 2021 | 10:43 AM
It will display the same image that is on our screen. If you want to try the software on your tablet. Go to the link below and click on the "update" at the bottom. That will allow you to install the promax software directly to your tablet.
Nitrous Outlet Promax
Old Apr 30, 2021 | 03:06 PM
sniffin94's Avatar
I put it on my surafce pro. Is there a reason it does not let me go full screen? It says the drivers are not installed and it is not connected. Just trying to make sure it would go full screen on a 7 inch table. )I currently do not have the tablet, checking before I buy everything.
Old Apr 30, 2021 | 03:47 PM
Unfortunately, it wont go full screen.
