Nitrous outlet fast 102 question
Old May 31, 2021 | 08:21 PM
Z28SteveA4's Avatar
Default Nitrous outlet fast 102 question
Im having a little trouble figuring out what wet kit if there is a kit that will work for the fast 102 f body setup. I am using factory style fuel rails also? I see a kit that has aftermarket fuel rail. I know about the 90-92mm fast f body kits. Any help will be great
Old Jun 1, 2021 | 11:01 AM
brandon@nitrousoutlet's Avatar
Nitrous Outlet Fast 102mm Plate System
This is the system you need.
Old Jun 1, 2021 | 03:14 PM
Z28SteveA4's Avatar
Thank you! That’s the one I thought just wasn’t sure of the factory fuel rail working or not
Old Jun 1, 2021 | 03:34 PM
You're welcome. That system comes with the correct fuel rail adapter for the stock fuel rails.
