Nitrous controller or not??
Old Jul 4, 2022 | 07:16 PM
shaun.harrison55's Avatar
Default Nitrous controller or not??
Hey guys, ive got a gen iv m6 I've just built a new motor with the usual mods, big cam, heads, rods, pistons all arp bolts thru out.
I'm running a Nitrous Express Plate kit on it. My question is do I need to run a controller I'm planing on running a 150 shot but eventually going to a 250 shot. When i step up to the 250 shot I'm going to run a Holley computer.
so for the time being do i need a controller for the 150 shot. I have set it up with a micro switch behind the pedal for wot activation
Cheers guys.
Old Aug 21, 2022 | 02:45 AM
TTur1996's Avatar
The Holley Dominator Box already has the progressive built into it, so don't waste your money buying another one. If your car hooks good it should be able to take a 150 out of the hole. I would add a button in conjunction with the Wot switch in case you need to wait till just after the launch. When you get the Holley, loose the button and let the progressive run the system. Then you have total control thru the run. They work fantastic.
