Engine build help/ recommendations
05 lq4.
4L80 shift kit and tci trans brake kit
E85 or 115oct
8.8 narrowed
Terminator x
317 heads
Ls7 head gaskets
BTR cam Specs: 233/248 .630"/.615" 111.5+2.5
BTR BRIAN TOOLEY RACING .645" SPRING KIT - STEEL RETAINER
CHROMOLY ONE PIECE PUSHRODS - 5/16" DIAMETER - .080 WALL THICKNESS - 7.400"
Holley single plane ego split intake
Holley 4150 1000cfm race throttle body
Nitrous express wet plate kit
My goal is low 6’s in a 2500-3000 pound car 28/10.5 slick
Local track is bare concrete road. Located in south fl
Any recommendations for a (kit) or even individual parts I appreciate it motor side ( wiseco,diamond,Mahle, k1). Hell even if you have converter or gearing recommendations that would help to. I don’t need any crazy expensive parts, I feel like these expectations to be a reasonably “budget/modest” build.
Thanks
TSP stroker crank, TSP billet I beams, wiesco pistons and .200 thick wall tool steel wrist pins.
I would go bigger on the cam and bullet proof the valvetrain( dual springs, linkbar lifters, 3/8 pushrods) Stud everything. Ls9 gaskets.
open the rings up big, I'm at .028, .035. I was having issues with crankcase pressure on motor so I threw two -10 off each breather.
****** runs hard, loves the gas. 400 on 2 kits and planning on more
