Bottle warmer
White wire from relay- grounded, Red from relay goes into pressure switch, Blue into warmer, Black from relay 12v to battery, Black wire on pressure switch 12v arming switch, 2nd black from warmer in also grounded
12V from the arm switch to the pressure switch, then from the pressure switch to pin 86 on the relay, and ground straight to pin 85 on the relay;
OR
12V from the arm switch straight to pin 86 on the relay, and ground to the pressure switch, then from the pressure switch to pin 85 on the relay.
THEN
Pin 30 OR 87 will be power straight from the battery, and the pin that is left of those two will go to the bottle heater. The other wire off of the bottle heater will go straight to the negative on the battery.
OR
THEN
The Nitrous Outlet Adjustable Nitrous Pressure Safety Switch is adjustable from 750-1200 PSI and helps your systems bottle heater maintain a constant pressure. To set the switch, tighten the set screw to increase pressure and loosen to decrease pressure. Only make adjustments of 1 turn at a time giving the bottle at least 10 minutes to stabilize between adjustments. One full turn will adjust the pressure by approximately 150 PSI.
The bottle heater switch will disengage when it reaches the set pressure, and will re-engage once the pressure drops at least 50 PSI. I would test the switch with it in open air, or if you have it on a manifold fitting off the bottle nipple, test it with the bottle closed, just to see if the switch functions at all. As I mentioned before, putting ~20A through it could have damaged the switch.
