NX jetting chart
Old Jan 9, 2024 | 06:00 PM
L672LS6V's Avatar
Default NX jetting chart
I pulled up a jetting chart for this 90mm plate system I have for my 05 cts-v, the chart reads @55 psi but my fuel system runs @58 psi, I do have an adjustable regulator so I could dial it back to 55 psi, but I would rather leave it at 58 psi, is there a formula to figure out jetting or should I just use the jetting chart at 55psi while using factory 58 psi?
Old Jan 9, 2024 | 08:44 PM
brandon6.0's Avatar
3psi want make a difference. Normal ls stuff runs around 53psi with vaccum to the regualtor
Old Jan 10, 2024 | 01:02 PM
Skizzy's Avatar
You'll have no issues running the 58psi using that jetting chart. I've got too many friends doing it with no issues at all.
