Stand alone and pressure regulator
Old Aug 24, 2025 | 07:32 AM
L672LS6V's Avatar
Default Stand alone and pressure regulator
I have a DW300 pump, -6 AN feed about to change to -8 AN feed with -6 AN return with an adjustable FPR running 58-60 PSI. Nx 90mm plate system 150-200 shot.
This is a two part question here;
1) do i need a FPR for the Nitrous enrichment solenoid, and if so what should it be set at
2) are -6 AN fuel rails going to be large enough?
I'm pretty sure i can get away with this, but I need some insight. I've had it all installed for a couple of years and it works, but I still havent sprayed yet (tuning myself and it's taking forever but its almost time)
Old Sep 3, 2025 | 07:13 AM
1988montecarloss's Avatar
dont need fpr for nitrous solenoid, but make sure you are using the right jetting for the fuel pressure it is seeing, (higher efi pressure wants a different fuel jet than low carb pressure for a given nitrous jet)
im assuming youre pulling fuel from the port on the rail?
-6 would be close but you say youre switching to -8 which should be plenty
best way to test if you have enough fuel flow is run just your fuel solenoid into a can under the hood and make a WOT pull while "spraying" just the fuel solenoid and datalog it, if youre seeing the same AFR as without the fuel solenoid spraying you have enough fuel flow
