Another Fueling question
Old Jan 20, 2026 | 04:49 PM
L672LS6V's Avatar
Default Another Fueling question
I got a stand NX alone system, planning using C-16 in there. I got alot going on under the hood with a FPR, fuel lines, nitrous line, battery lugs (moved the battery to the trunk already) etc...can I mount this Stand alone in the trunk? Or do I need to change everything under the hood? I left my in -6AN in place for stand alone from trunk since I upgraded my fuel lines to -8.
Old Jan 21, 2026 | 10:36 AM
Forcefed86's Avatar
As long as there is a sealed fire wall between the driver and the tank I believe you can mount it anywhere. They also like to keep fuel tanks inside the rails. Look up the NHRA specs on aux tank locations and rules.
I’d go M1 in the aux tank. Get alot more cylinder cooling, higher octane, and cheaper. Nitrous outlet has all the jetting charts to use with methanol. Better fuel all aorund and since you only spray when the N20 is active you don’t ahve to deal with any of the nonsense a straight alky cars do.
