Window switch
Old Jul 29, 2004 | 09:00 PM
HAMRHEAD's Avatar
Default Window switch
I've searched and I know the tach wire is the #10 white wire at the bottom of the PCM. Yet I see no fricking numbers just a jumble of wires. How do I know which is the #10 white wire? May be a stupid question but **** it I'm spent. I just want to make sure.
Old Jul 30, 2004 | 08:02 AM
860 Performance's Avatar
Hamrhead, there are tiny numbers embossed onto the connector that the wires feed into.
Is this a vette or camaro/firefird? Only reason I ask is because the vette has multiple computers, and the one with the tach signal is behind the front pass side wheel. You access it by removing the inner wheel-well.
Old Jul 30, 2004 | 11:09 AM
HAMRHEAD's Avatar
It is a 2000 Camaro. I didn't see any numbers but it was a long day and frustration was setting in. I'll go look again. Thanks.
