Best way to check fuel solenoid
I just installed a N/X wet kit on my Hawk and want to make sure the fuel is sprying before I put the nitrous to it. it is a used kit so that is why in making sure. all the solenoid clicked when I installed them so I know there getting power. whats the best way to check to make sure fuel is flowing?
thanks for any help
thanks for any help
It depend on how you have the kit wired. First of all if you have a window switch you need to replace the ON rpm pill with a wire loop. This will set the ON rpm to 0. Now make sure that their is absolutly NO NITROUS in the feed line. Unhook the fuel line from the the nozzle and put it in a cup. Now if you don't have a Fuel Pressure Safty Switch you can just turn the ignition to ON, arm the system, and tap the WOT switch a couple of times. If you have the safty swtich just turn the engine on, arm the system, and tap the WOT switch.
