TNT 75 wet = dry 100?
Old Aug 7, 2004 | 12:10 AM
NOTFAST's Avatar
Default TNT 75 wet = dry 100?
Would they be fairly close in gains?
I would think so.
Old Aug 7, 2004 | 12:43 AM
JoeDirt's Avatar
thats about right I think if you spray the dry at 1000 psi - 1050 psi .
Old Aug 7, 2004 | 10:23 AM
NOTFAST's Avatar
does a dry kit 'hit' as hard as a wet shot?
Old Aug 7, 2004 | 07:12 PM
JoeDirt's Avatar
If the pressures up and the A/f is the same it should. NOS rates at the flywheel and tnt / nx the rear wheels but given an equivelant shot you should see the same end result.
Old Aug 8, 2004 | 07:20 AM
koolrayz's Avatar
nx shows different size jets than nos does for the same size shot thats why they say you get more horsepower with there kits. when in fact you get more HP because you use larger jets
Old Aug 8, 2004 | 08:51 AM
B-MAN's Avatar
I've experieced dry, wet, and direct port nitrous. One thing I know for sure is that direct port hits really hard next to nitrous that is being fed through an intake. it doesn't get more instantaneous.
