What else for an A4?
Old Aug 13, 2004 | 08:34 AM
Cerebrex's Avatar
Default What else for an A4?
What else do I need for my nitrous kit to run safely on a 98 A4 with a 2001 LS1 w/ 5k miles on it?
Here's what I have, quoted from the guy I bought it from:
"Brand new Dyno Tune 10lb bottle painted silver,10lb bottle brackets and blow tube
4an mainline and lines from soloinds to nozzle and fuel rail
compucar nitrous filter,compucar fuel soliond,compucar nitrous soliond
dyno tune purge soliond
and 50 & 100 horse jets"
Thanks for any help in advance.
Old Aug 13, 2004 | 02:07 PM
GM Muscle's Avatar
Does it come with electronics like a relay, switches, and a WOT switch? A window switch is a good idea to help ensure your tranny doesn't get hurt.
Old Aug 13, 2004 | 02:45 PM
Cerebrex's Avatar
no WOT switch. Is it necessary?
Old Aug 13, 2004 | 03:12 PM
GM Muscle's Avatar
Yes, you would deffinatly want one. That way you can arm the system before you go WOT and it will automaticly turn the system on when you go WOT and shut the sytem off when you let off. It would be pretty dangerous running without one. The NOS one wiht bracket is $12.
Old Aug 13, 2004 | 09:38 PM
next's Avatar
WOT switch as mentioned is good to have but necessarily a safety measure. It's definitely a convenience to keep from having to time your activation with a momentary switch. Fuel pressure safety switch and a window switch are good safety measures to take. Adding a bottle heater is a nice to have as it keeps the bottle pressure in the right range as you'll discover when pressure drops, so does your power.
