NX Tpas wiring question
Old Aug 14, 2004 | 10:20 PM
Thermofish's Avatar
Default NX Tpas wiring question
Which wire (pin number) does the Tpas wire get its throttle position data from on the PCM? I keep seeing people say "the dark blue one", but which pin, on which connector. It is a 2000 TA.
Thanks
Old Aug 15, 2004 | 12:21 PM
Thermofish's Avatar
I can't seem to find this info anywhere! Does anyone know which pin it is on the PCM? This is the last thing I need to hook up before I can use my kit for the first time.
Thanks!
Old Aug 15, 2004 | 04:48 PM
DERTY's Avatar
The Bull
Look at the TPS on the throttle body and you will see a dark blue wire. Fortunately it is only one of a few in the car that looks like that color. What you can do is disconnect that wire and use a continuity gauge to find the other end of it. I don't remember what pin that is right off the top of my head, but this is how I found it for mine.
Old Aug 15, 2004 | 05:58 PM
860 Performance's Avatar
Default Tps
Unfortunetly, I dont know which pin either. I always tap of the wire underhood. Like Derty said its real easy to find. Its the dk blue wire off the tps.
Old Aug 16, 2004 | 08:06 AM
Thermofish's Avatar
Well, I found it. For future reference for anyone searching this subject, it is pin 24 on the red pcm connector.
