bottle valves?
Old Aug 20, 2004 | 06:42 PM
rons 00z's Avatar
Default bottle valves?
whats the diffrence between all these valves? if they all allow 1100 psi then for the most part should be the same. do they change the volume of nos that blows through the line? i only plan on blowing a 150 shot, so will a high flow valve really matter in my case?
Old Aug 20, 2004 | 07:08 PM
860 Performance's Avatar
Default valves
There is a big differnece in valves. Some restrict the flow more than others. If your only spraying 150hp, it shouldn't really matter. I dont know of a valve that would give you trouble at that level.
One other thing about valves, maybe someone else can shed some light on this as I am not 100% confident, but, I have seen two ZEX valves go bad. You can't close them, the valve shuts but Nitrous still leaks out slowly. Does anybody know if Zex uses a different seal than the other mfgr's?
