just to make sure...
Old Aug 24, 2004 | 12:40 AM
Timberwolf's Avatar
Default just to make sure...
an MSD window switch can be run off the white wire from the pcm, correct? no tach adapter is necessary?
Old Aug 24, 2004 | 12:53 AM
Magic Chicken's Avatar
12 Second Truck Club
That is correct for my MSD digital window switch. I'd guess it's the same for the non-digital versions, but can't be certain without looking at the instructions. Do you have the digital one or the "pill" one?
Old Aug 24, 2004 | 06:43 AM
Timberwolf's Avatar
haven't bought one yet, but was plannign on doing that today. Just wanted to see if I needed the tach adapter or not.
Old Aug 24, 2004 | 08:27 AM
Timberwolf's Avatar
I was just reading a guy's ad for a window switch he was selling and he makes the following statement:
"MSD RPM ACTIVATED WINDOW SWITCH MODIFIED BY MSD FOR 5 VOLT SQUARE WAVE SIGNAL THAT LS1 VEHICLES HAVE"
What's that all about?
Old Aug 24, 2004 | 11:24 AM
Turo's Avatar
when you buy the msd rpm window switch, you have to cut 2 wires to make it run in 4-cylinder mode, so it will work with LS1's. dont worry, it is REALLY simple and the instructions tell you how to do it. that's true of the "pill" window switch, i dont know much about the digital one.
Old Aug 24, 2004 | 11:28 AM
I didn't have to modify or cut anything to get the digital one to work.
Now that there is a digital one, it's pretty much obsoleted the "pill" version. And after you buy the switch and all the "pills" you need, the digital one is much cheaper.
