nitrous a/f ??? on a stock motor
Old Aug 31, 2004 | 10:36 AM
h777's Avatar
Default nitrous a/f ??? on a stock motor
what is a good air/ fuel reading on a stock motor with nitrous????......i want to keep it safe but not too rich would 12.5 to 1 be ok or should i look for something in the 11s....thanks for any help
Old Aug 31, 2004 | 08:41 PM
02bluess's Avatar
TTT
I'm also curious as to what the "optimal" a/f ratio on the spray is??
Although my engine's not quite stock
Old Aug 31, 2004 | 10:34 PM
Navy David SS's Avatar
Mine is set at 11.8-12.0 - dyno tuned. IMO would go any leaner. Leaner is not meaner on nitrous. It just
David
Old Sep 1, 2004 | 06:46 AM
VIl's Avatar
VIl
The optimal A/F ratio is 12.5-13. But it's safety to fall the digit to 11 (with nitrous only). Let be some more fuel, it's may prevent the detonation. Much more dangerously to keep a poor mixture...
Old Sep 1, 2004 | 08:36 AM
next's Avatar
I'm just over 12-1 and am comfortable with that based on what the car is doing on the dyno. You will make a little more power going leaner but it's not worth the risk.
Old Sep 1, 2004 | 09:00 AM
hellbents10's Avatar
LS1Tech Sponsor
I have herd anywere between 11:1-12.8:1. I usually tune for 11.5:1-12:1.
Old Sep 1, 2004 | 10:01 AM
koolrayz's Avatar
Call me mister pig rich but im 10.8 to 11.1
Old Sep 2, 2004 | 11:48 PM
Honez's Avatar
I run 12.8 or so on mine.
