timing tuner/ nitrous wiring help!
Old Sep 2, 2004 | 12:39 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
Default timing tuner/ nitrous wiring help!
can anyone tell me how they wired up there 5177 kit to the timing tuner?it looks like you have to rearrange some wires.thanks guys
Old Sep 2, 2004 | 03:42 PM
marlowchris's Avatar
I am not sure about a 5177 kit, but I will try to explain how it is wired to a NX kit. I am sure they are the same. The "T" pigtail from the tuner gets plugged into the crankshaft position sensor, behind the starter. The 2wire wht/gry pigtail from the tuner gets wired into the solenoid relay. The white wire gets wired into the relay signal supply(this should be the wire coming from your WOT switch). When this wire is hot the tuner is activated. The gray wire gets wired into the negative side of the reealy. This wire grounds the relay at a set RPM. A diagram would be much easier to understand. PM me your email address and I will send you a picture.
