Added a FPSS and a window switch and got probs
Old Sep 6, 2004 | 09:04 PM
bsmith98's Avatar
Question Added a FPSS and a window switch and got probs
Yeah I added a FPSS and a Window switch and my kit stopped working. I followed the directions and it looks right. What are some stupid things i could have done wrong?
Old Sep 6, 2004 | 11:44 PM
taqwache's Avatar
has to be an open curcuit somewhere. is the motor on when you are testing it. if not the FPSS will open the circuit since the pressure will be 0psi.
Old Sep 7, 2004 | 09:45 AM
bsmith98's Avatar
Yes the motor is on when we tested it. We even by passed the fpss by connecting the two wire on it together. Still doesn't work.
Old Sep 7, 2004 | 12:18 PM
SDB's Avatar
SDB
then it is a window switch or wiring problem....get a test light and check the wiring, then try bypassing the window switch.
Old Sep 7, 2004 | 08:36 PM
BMN's Avatar
BMN
Is your window switch in 4cyl mode?
Old Sep 8, 2004 | 08:52 AM
Nice SSer's Avatar
When I hooked my window switch up my TNT system wouldn't activte. Everything was tested over and over and was hooked up correctly. Turns out, I had to send my window switch to MSD to have it converted to a 5 volt square wave.
Old Sep 11, 2004 | 01:01 PM
shortdog's Avatar
9 Second Club/Nitrous Mod
bsmith, did you ever figure out the problem with your window switch?
