fuel tap?
ok on my mustang i had a the shrader vavle wich unscrewed, then i put in the NX bit inside where the shrader valve was.
now im working on the ls1 and i noticed that it has a test port on the drivers side fuel rail right in front...However that doesent look like it unscrews
i have the NX unversal kit, so i have a little hollow bit that is supose to screw into where the sharder valve is/was.
But right now i have no idea on how to get fuel taped
please please help.
please please help.
ok i think i may have figured it out....
the line that NX sent me to run from the fuelrail/valve....seeems to screw right on to the drivers side fuel rail (at the front of the rail there is a black cap under it is a valve) anyhow the Line Screw onto it's threads perfetly, however it has a stem in it (like the stem in side a tires valve stem).............do i just remove the stem inside that port?
Closed ex-Sponsor Account
On the LS1 cars fuel rail there is no need to install the fiting like on the Ford cars. Remove the schrader valve then install the -4 red hose directly onto the rail. It is has the same threads as a -4 line. Call me if you need anything else. Also the universal kits 20915 has sevral fittings that are not needed for the LS1 cars.
Ricky
Ricky
please please help.
please please help.
