N.O. used to cool a forced induction intake?
Old Sep 16, 2004 | 01:56 PM
FASTONE's Avatar
Default N.O. used to cool a forced induction intake?
On a race-only forced induction set-up could you build a intercooler that uses the N.O. as a cooling agent thru the air cooler?This would be a 1/8 mile track,5 to 6 seconds of cooling needed. Or could you use some other gas?
Old Sep 16, 2004 | 02:18 PM
Noyzee's Avatar
8 second mod
I made a custom spray bar for my old set up. mounted it right infront of the IC, and sprayed it while racing. it kept my IAT down about 10* depending on outside air temp. i could have used c02, but just used n2o.
it worked well I believe NX sells a kit now
Old Sep 16, 2004 | 02:57 PM
FASTONE's Avatar
Thanks Noyzee!!!
Old Sep 16, 2004 | 02:58 PM
Noyzee's Avatar
8 second mod
no problem. matter of fact, i still have alot of the parts i used if you want them. shoot me a pm
Old Sep 16, 2004 | 05:32 PM
eviltwins's Avatar
I too lost maybe 10* by using it. If you want to cool down charge temps use a methanol injection kit. We see inlet temps BELOW AMBIENT on my Dad's Z06 with a D1SC pushing 12 pounds, using an alkycontrol.com methanol injection kit. Cheaper to refill too, and you can run significantly more boost on pump gas.
