N2O with HPP3 tuning?
Old Sep 18, 2004 | 12:49 PM
OUT2WIN's Avatar
Default N2O with HPP3 tuning?
My mods are in my sig and I was wondering if I should pull off the HPP3 engine tune and just use the hpp3 for top speed limiter and shift points? I will be running 92 octane fuel (with a little octane boost) and a 100 shot wet kit from Nitrous Works!
Old Sep 18, 2004 | 02:05 PM
jamnut's Avatar
If you are running the power programming on the HPP3 I would remove it before spraying due to the fact that it advances your timing, when you actually want to pull timing on the spray. Just use the HPP3 for stuff like you stated above, shift points, speed limiter, rev limiter & stuff like that, just not the power programming.
Old Sep 19, 2004 | 07:22 PM
Need2gofaster's Avatar
That damn thing is usless besides changing your rev limiter and gears. And you dont want to advance timing while spraying!!
Old Sep 20, 2004 | 08:56 AM
tooquick2beslo's Avatar
Yea just stick with the 87 octane. I havent had any problems spraying with my truck on the 87 octane tune. Also like you stated make sure you run 93 octane when spraying.
