How much timing are you taking out ?
Old Sep 30, 2004 | 10:45 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Default How much timing are you taking out ?
Im going for the first time this year on the bottle.I have a DP setup and i'm running about a 200 shot maybe a little less.How much timing should i pull out.I Have edit so it's not a problem and if you know were you start taking timing out on the chart in the load catorgy. Thanks for any input. mike
Old Oct 1, 2004 | 02:43 AM
SStolen's Avatar
I've always heard the general rule of thumb on a cammed car is to run 28 degrees on a 100 shot and you are fine. Another rule of thumb is to pull 2 degrees for every 50hp over 50. That would put you at 24 degrees of timing. You will probably lose about 8-15 rwhp on motor but who cares. Hoped I helped a little.
Old Oct 4, 2004 | 09:47 PM
slow trap's Avatar
i'm running 28* on my cam only car, 22* on a 150 wet shot.i'd say run 20-22 degrees at 12.o afr.
Old Oct 4, 2004 | 11:14 PM
GueSS Who's Avatar
I run 18 degrees timing on a 300 shot with 112 octane fuel at about 11.6:1 afr
