Purge wiring question
Old Oct 3, 2004 | 06:54 PM
Chingon's Avatar
13 Second Truck Club
From: Pueblo de Nuestra Señora la Reina de los Ángeles de la Porciúncula
Default Purge wiring question
I installed the NX kit on my truck and I have the purge kit I want to wire up now. About the purge button, I know one wire goes to the purge noid, but about the other wire, it says to connect it to the middle "ACC" connection (middle connection) on the nitrous arming switch, which already has the WOT switch connected to it.
Do I just splice the wires together???
Thanks in advance
Old Oct 3, 2004 | 07:02 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Mine is hooked up to a diffrent power source. Purge noides don't take any power so i hooked it up to a direct power source and no problems.
Old Oct 3, 2004 | 07:24 PM
Deckhand's Avatar
I just tapped off the power source prong off the arming switch, so i have to activate it, to be able to purge. Hope you get it hooked up.
Old Oct 3, 2004 | 09:07 PM
Chingon's Avatar
My concern is connecting the one wire from the WOT switch to the ACC (middle prong) on the arming switch, AND the push button to the same ACC on the arming switch. Is that the correct way to do it and will I damage anything, like melt wires or whatever if I splice these 2 together?
Old Oct 4, 2004 | 03:17 PM
deezel's Avatar
I used a separate relay to power my purge solenoid. Completely separate circuit.
