DP 300shot
FAST intake and 78mm TB
JE pistons/pins/rings
Lunati Pro Mod rods
Stock Crank
AFR 205 heads
MLS gaskets
ARP head/main studs
ARP2000 rod bolts
Hot Cam
1 3/4 Kooks headers
Racetronix in tank pump
Aeromotive rails
37lb Racetronix injectors
OR
Complete Lunati 382 reciprocating assembly
AFR 205 heads
MLS gaskets
ARP head/main studs
ARP2000 rod bolts
Hot Cam
1 3/4-1 7/8 Kooks headers
Aeromotive rails
2000 6spd T/A w/ full suspension front and rear (set for road racing/street use)
Moser 12bolt limited slip
16in wheel w/ET street
Timing Tuner
Stock trans
Spec 3I clutch w/billet AL flywheel
Stock driveshaft
How much timing would you pull from the stock tune for this?
Should this be progressive or is throwing it straight at the motor Ok?
MOST racing would be from a roll
Spray would start in second gear if from a dig
So far this guy is insistting on this HotCam. I'm still trying totalk him out of it.
thanks
What I am mostly looking for with the question I asked was whether or not the parts combination would reliably hold up to the 300 shot.
I would hope that anyone that has used N2O would not be silly enough to go straight to a 300 shot and hope things work.
This car would be tuned by me and the shot would be worked from around a 150 up to the 300 range. Just as I did with my car starting at 75 and working my way up to the 150.
As far as progressive vs straight up, you'll have to try that out. Just depends on how well your car likes it.
