need fitting for 5177, anyone have a #
Old Oct 17, 2004 | 10:55 PM
DeepBlueZ's Avatar
Default need fitting for 5177, anyone have a #
ok i just finished up installing my 5177 kit. i bought the kit used and it only had one of the 2 solenoids. it's all ready to go but i just got a brand new super-powershot solenoid from my friend. i wanna run this in series (the way the kit is supposed to come) with the other rather than relying on the other (which is pretty old and has never had filtered nitrous run through it.) to close (last thing i need is to have that one noid stick open and take the motor with it.) i'll rebuild the second noid eventually but for now, i just want to run the two of them, the way it should be.
anyway does anyone know a part # or something for the small fitting that connects the "out" side of the first solenoid with the "in" side of the second one (keep in mind its got to be the right length to position both solenoids on that little noid bracket that comes with the kit.)
thanx.
Old Nov 14, 2004 | 08:04 PM
v8juice's Avatar
I have this system and the NOS part is a nitrous solenoid tee #17242 with a 1/8 npt plug(blue) that is #17210
Old Nov 17, 2004 | 04:48 PM
DeepBlueZ's Avatar
great, thanks a lot.
Old Nov 19, 2004 | 03:36 AM
PREDATOR-Z's Avatar
If run in series they have to be the same size solinoids. You can make an easy 2 stage by running each noid separately.
Old Nov 19, 2004 | 03:07 PM
DeepBlueZ's Avatar
as far as i can see they are the same, both super-powershots (the smallest ones NOS makes i believe)
the two stage idea is cool but i don't have enough fuel for more than a small shot...i got a cam going in soon too and i'll be running close to the edge on a totally stock fuel system with cam+spray.
later on, i might hit it with a dual stage.
