Should I upgrade the FP and which one??
Old Oct 27, 2004 | 04:36 PM
Ravenous T\A's Avatar
Question Should I upgrade the FP and which one??
I have a Cold Fusion Nitrous wet kit, I am gonna run a 100shot, my mods are on my cardomain page. I have a G5X3 114LSA cam and I plan on using worked 6.0 heads(get the comp to 10.5:1). Do I need a better fuel pump and do I need to get bigger injectors. and if so, which ones?
Old Oct 27, 2004 | 06:01 PM
jaywoo's Avatar
With a wet kit, you're not asking anything extra from the injectors, so you should be fine with the stockers, at least until you upgrade the heads. You may want to consider a set of 30# injectors when you do the head swap. With just a 100 shot, your stock pump should be good also, but hey, a new pump couldn't hurt. There are several good ones, I'm running a Walbro 255lph and occasionally spray a 200 shot on it with very good results.
