TPS and FPSS acting up…
NX TPS
I bought the electronic TPS from NX. This unit works very well when it’s dialed in, but somehow it’s getting out of adjustment or the signal isn’t very consistent.
The NX TPS reads resistance and you dial it into the amount of resistance that is present when the TPS on the throttle body is reading WOT. I dialed mine in one turn past the point when the light on the NX TPS aluminates and it worked fine for a while. Then I went to dyno my car and the nitrous wouldn’t hit. I checked everything out only to find that the NX TPS wasn’t reading WOT, I had to adjust it out another 4 turns to make the light come on.
A few weeks later I was out and had the system armed. I hit WOT and nothing, checked my NX TPS and it wasn’t reading it.
Could this be a faulty NX TPS? Or is it something with the connection to the TPS on the TB?
NX FPSS
I’m only assuming this is the culprit for my symptoms, so.
When I’m spraying in 3rd, sometimes I can feel pulsing of power like the system is kicking on and off very rapidly. It doesn’t do this all of the time either.
I have a Racetronix fuel system and the FPSS retains factory settings. Could the FPSS be the cause?
I'm pretty sure I'm not running out of fuel, so it has to be something with the FPSS.
Ricky
NX TPS
NX FPSS
