I can't get my MSD Digital Window switch to work.....HELP
Old Nov 23, 2004 | 04:43 PM
FSANE's Avatar
Unhappy I can't get my MSD Digital Window switch to work.....HELP
I wired it just the way it sais. Still no luck.. Help
Old Nov 23, 2004 | 05:08 PM
BMN's Avatar
BMN
Did u put it in 4 cyl mode? What pin # and color of plug on the PCM did u tap into for the tach signal?
Old Nov 23, 2004 | 06:54 PM
FSANE's Avatar
The Diagram features an old style MSD box, I have the new digital one. I called MSD and they sent me this diagram. They said the wireing is the same.
I put it on MODE 1 which is for LS1 induvidual coils ignition.
Old Nov 23, 2004 | 07:14 PM
frey51's Avatar
Isnt that diagram for an rpm activated switch, which has differnt wiring than the window switch? I am sure that there is at least one extra wire on the window switch that is used to close the circuit. I am in a similar situation, but havnt hooked up my window switch yet becuase I dont know how to. BTW, I have the switch which requires the pills so it too is may different than the digital.
Old Nov 23, 2004 | 08:30 PM
BMN's Avatar
BMN
nah, don't use mode one. It's a misprint I guess. LS1's put out a 4 cyl tach signal from the PCM to the tach guage. How exactly does it work, it just does. Like a posi-trak on a Plymouth. It just does! lol jk
Old Nov 23, 2004 | 08:43 PM
FSANE's Avatar
so is my wireing correct?
Old Nov 23, 2004 | 08:46 PM
cyipher's Avatar
Looks correct.
Old Nov 23, 2004 | 08:50 PM
frey51's Avatar
What about the wiring for a regular pill activated window switch? What are the differances, and how should I go about wiring mine up?
Thanks
Fry
Old Nov 23, 2004 | 09:40 PM
FSANE's Avatar
I set it at cyl 4 and still nothing.
Old Nov 23, 2004 | 09:57 PM
BMN's Avatar
BMN
Uhm, one more quick ?. Do u have a NX or NOS kit. It's NOS in the pic but that doesn't mean u have one. I forget if the yellow is switched ground or power. You need to have the switched ground wire to trip your relay.
Old Nov 23, 2004 | 09:58 PM
JoeyGC5's Avatar
I thought the fuel switch was to be put in series with the window switch. Not in series with the solenoids?
Old Nov 23, 2004 | 11:12 PM
Ed Blown Vert's Avatar
The fuel switch can't handle the current of the solenoids. Put it inline with the window switch. In fact, the FPSS might be bad now.
