NX kit on M6
Old Nov 23, 2004 | 06:52 PM
NX_CaGEdApE00's Avatar
Default NX kit on M6
how do i mount the wot switch to the tb?? i have the efi nx kit..
if i get the msd window switch which is better digital or the one with the pills??
And will i still need the wot switch with that??
Also what fuel pump should i run?? Walbro 255 or racetronics or what??
I have 373 hp and will be spraying 75- 150 hp maybe 175.
thankks
Old Nov 23, 2004 | 07:20 PM
frey51's Avatar
I have my wot switch mounted directly under the tb. Ther is a screw there that you can use to mount it on. You may need to fab up a little brackt that will put the switch into the correct location, depending on the bracket that came with the switch. I got my stuff used, so I already had a bracket that could be bent around to get it into position.
I am not sure if either of the window switches is better than the other, I would say go with what ever one you want. Fuel pump...I dont know, sorry.
Fry
Old Nov 23, 2004 | 08:03 PM
Nitro Dave's Nitrous Outlet's Avatar
You will have to bend the bracket in the kit to fit.If you do not like that we offer a premade billet microswitch bracket and micro switch.
Either MSD will work.Yes you will still need a micro switch.
You would also be fine with a single intake walboro pump.
Dave
