Help! wiring switchs
Old Nov 26, 2004 | 02:36 PM
phoenix's Avatar
Default Help! wiring switchs
how did you guys run the wire from the relay to the arming switchs??? i cant find any good places on the firewall.
Old Nov 26, 2004 | 02:38 PM
Z28Venom's Avatar
You can use wire loom and run it across the engine bay and through the firewall behind the PCM.
That's how I did it. You have to remove the passenger side kick panel and underdash cover to gain access to the hole.
There are also 2 10mm bolts holding the PCM down. Just remove those and slide the PCM to the side.
Old Nov 27, 2004 | 09:45 AM
phoenix's Avatar
sweet thanks a lot!
Old Nov 27, 2004 | 03:04 PM
wbw2's Avatar
ditto, I used that PCM wire hole too, except when I wired my nitrous, I went ahead and ran about 5 wires through at once for other things, line lock, purge, etc.. trust me, it's worth it, it's a pain in the *** going through that hole!
