Mostly want to stay n/a but have nitrous on the side, help
Old Nov 27, 2004 | 11:01 AM
Tiger2o69's Avatar
Default Mostly want to stay n/a but have nitrous on the side, help
I Just bought a nx wet kit and want to keep it for those times that I just need it. I dont want to use it all the time so I want my car to remain as fast as it is now.
So im wondering if I have to use ngk6 plugs ect. I dont want to do anything to hurt my all motor performance since that what I run most of the time. I am already running pretty rich due to my headers. Last time on the wideband it was 12.1 to 12.3 will that be fine to run with?
Old Nov 27, 2004 | 04:48 PM
next's Avatar
What size shot are you planning?
Old Nov 27, 2004 | 05:38 PM
WillieD's Avatar
On motor that is a little rich, but when spraying it is good to have more fuel. If you are going with a wet kit, I would put the next step up fuel jet in to make sure it is safe. On a dry kit you will want some tuning to make sure you are running rich enough for the N2O.
Old Nov 27, 2004 | 07:03 PM
Tiger2o69's Avatar
I will be using the 100 shot every once in a while when i go to the track and maybe keep the 50 shot in while on the highway, Just in case I need a little extra. I wont be using anything above the 100.
I have hp tuners so I can make some adjustments if necessary.
Old Nov 27, 2004 | 09:01 PM
Z28Venom's Avatar
I believe that you're still going to have to run colder plugs. They shouldn't hurt N/A performance too much.
Old Nov 27, 2004 | 09:15 PM
next's Avatar
You're probably hurting more running 12 -1 a/f NA then you would be with the switch to TR-6s. That's a good safe ratio for the 100 shot though if you are going to spray it. I think you can get by with the 55s, but there really wouldn't be much loss except a few hp by switching to them.
Old Nov 28, 2004 | 12:16 PM
Tiger2o69's Avatar
yeah as soon as I figure out how to lean it up w/ hp tuners i planned on doing so.
What could be the outcome of keeping the tr55 and running the 100 shot like once every 4-5 weeks? Or just in general running them with nitrous?
