What Settings For Window Switch?
Old Nov 29, 2004 | 02:40 AM
99Ws6TransAm's Avatar
Default What Settings For Window Switch?
Gonna start off with a 100 wet shot. NX kit. Have a fuel pressure safety switch, Harlan window switch, bottle heater,Throttle activation switch.
What rpms should i set my switch for on and for off?
Old Nov 29, 2004 | 03:34 AM
redrocketls1's Avatar
3000 to 5800 is safe... some even only go 5600.. some go more
i built custom pills for mine by mapping out the resistance and putting a adjustable resistor on the back of the pill... worked absolutely perfectly. the reason this has a reason in ur thread is.. i sprayed 2250-5950 probably 20 times on a 150 shot and didn't hurt anything.. however with my stall im no spraying safely at 3000
all were 150 shots stock motor and rear
if i were you id prolly start at 3000 and 5800 on a 75 shot and base it on available traction!
