Full Throttle Activation Switch?
Old Dec 5, 2004 | 09:37 PM
99Ws6TransAm's Avatar
Default Full Throttle Activation Switch?
I got one of these with my kit that i just purchased. It was said to be mounted behind the gas pedal so it would activate at wot...I see no way of mounting this im confused? How does it mount? I dont know if i like that set up..
Where can i purchase a WOT switch for a wet kit?
Old Dec 5, 2004 | 09:43 PM
tonyt123blue's Avatar
Are you joking?I think it says mount it behind the throttle body under the hood.when you go 100% the throttle pulls the metal bracket until it contacts the switch and activates it.
Old Dec 5, 2004 | 09:45 PM
CAT3's Avatar
Restricted User
Do a search for WOT Switches in this section. You should find quite a few.
Its hard to explain the way to bend it, but if it is a standard WOT Switch, it will be mounted to intake, behind/next to, the throttle cable bracket on the pass side of the TB. It has to bent IO for it to work right. Hooking to the pedal is a R-PITA.
Good luck.
Charlie
Old Dec 6, 2004 | 08:46 AM
Nitro Dave's Nitrous Outlet's Avatar
Correct that stock one will mount off the throttle body.If you do not want to mess with bending one to fit we carry custom built billet brackets.They come with microswitch and all hardware.They normally sell for 34.99 but are on sell right now for 29.99.We also carry a electric TPS switch that will work off of tps voltage for 89.99.
Dave
Old Dec 6, 2004 | 07:28 PM
NaughtyIROC's Avatar
Here's a pic of how a custom one (by Jimmy Jam's) looks mounted
Old Dec 6, 2004 | 08:41 PM
thanks...i figured it out.
Old Dec 6, 2004 | 09:20 PM
And here is a pic of a custom Billet one.You can bend your stock one off these same bolt to work.
CLICK LINK...
http://www.nitrousoutlet.com/outlet/...le_bracket.pdf
Dave
