Fuel Line
Old Dec 6, 2004 | 08:42 PM
99Ws6TransAm's Avatar
Default Fuel Line
On the ls1..when you install the fuel line..it installs from the solenoid to the connection on the outside of the fuel rail. Well dosent that fuel rail work like a tire stem? Were you have to push the pin in the middle to release fuel? Does that have to be taken out and then the fuel line installed?
Old Dec 6, 2004 | 09:17 PM
Nitro Dave's Nitrous Outlet's Avatar
You are correct.Remove the stem and screw your line on.
Dave
Old Dec 6, 2004 | 10:37 PM
will a stem remover that you use for a tire stem work? How much fluid is gonna come out?
Old Dec 6, 2004 | 10:46 PM
cyipher's Avatar
yes a tire core removal tool will work, but I first bleed out the pressure with a screwdriver and a rag
Old Dec 6, 2004 | 10:59 PM
sweet!
