Help with purge install
Old Dec 9, 2004 | 06:05 PM
BLK02WS6's Avatar
Default Help with purge install
I picked up a used TNT F1 kit and it came with a NOS purge kit. I have the instructions for the F1 kit, but nothing for the NOS purge kit. It seems pretty straight forward, but I wanted to make sure I get it right. Here are a few questions I have:
I have a small strainer fitting - does it go on the inlet of the purge soleniod?
Is it best to put the purge solenoid as close to the N2O solenoid as possible?
Do you just ground one wire from the purge solenoid, and run the other to the momentary switch which supplies 12V?
Thanks for any help!
Old Dec 10, 2004 | 07:03 PM
jwitt2's Avatar
i put the purge solenoid right before the n2o solenoid... i don't think that it does matter where you do put it though.
as for the wires, your assumptions are correct... that is exactly how i did it with my TA...
have fun with the kit man...
Old Dec 12, 2004 | 03:57 AM
BottleRocket's Avatar
put it as close to the solenoids as possable so you can get as much air out as you can. And your wiring sounds right, just put power to your switch, wire the other side of the switch to the noid and ground the noid.
Old Dec 12, 2004 | 08:08 PM
BLK02WS6's Avatar
Thanks guys!
