wire running...
Old Dec 18, 2004 | 11:31 AM
'02SS's Avatar
Default wire running...
all right boys,in a couple of days im getting my nx switch console(ashtray),nx remote bottle opener(spare tire well),and the 860 heated bottle brackets(also spare tire well).can you guys clue me in on what wires i will have to pull?i already have my arming switch in the ashtray,so i think ill use my switched hot there and pigtail it(im going to test it to see how much its drawing)i know the heated brackets must come w/ a relay,but does the opener?TIA.i appreciate all your guys' help. p.s. if theyre both relayed;then most likely i already know what to do;each relay gets a chassis ground,constant hot,switched hot and wire from the device im running right?
Old Dec 18, 2004 | 11:49 AM
'02SS's Avatar
also does any1 know how many amps the F2 solenoids draw?BTW im using the big brown wire under the steering wheel in the wire block under there,for my switched hot,thanks.
