Do I have everything?
Old Dec 23, 2004 | 02:27 PM
Caribe's Avatar
Default Do I have everything?
Well, I finally decided to go with a nitrous kit. I will be using the Zex wet kit for only a 100 shot. I won't be running more than 100 and the deal I got on the whole kit was pretty good. I am also getting a TSP 233/239 cam at the same time. So do I have everything I need?
1. ZEX WET nitrous kit
2. Bottle heater, purge kit, pressure gauge, safety blow out tube
3. Fuel pressure safety switch and Nitrous filter
4. MSD Digital window switch
5. NGK Tr6 plugs
After all is installed I will be getting the car dyno tuned.
Do you think I will need an aftermarket fuel pump running a 100 shot? (Walbro 255)
Old Dec 23, 2004 | 02:51 PM
tonyt123blue's Avatar
maybe but I doubt it.check your duty cycle on your injectors that should tell you how you are doing on fuel.
Old Dec 23, 2004 | 03:37 PM
TigerFan187's Avatar
That is a sweet setup man! I just got my system done and I bought everything you can think of. The guy that did my install was pissed lol! The only thing that you need to et if your doinf window switch is a WOT switch of some sort!
Old Dec 23, 2004 | 03:42 PM
Caribe's Avatar
The kit comes with a TPS switch that engages the N2O at wot.
Old Dec 28, 2004 | 03:41 PM
riceyum's Avatar
i would say you will be good with a stock fuel pump i used to have a zex kit and their 100 shot is more like an 80 shot.
