NO2 damage??
Old Dec 24, 2004 | 10:00 PM
seabirdak's Avatar
Default NO2 damage??
Does running NO2 damage the motor in any way?
Old Dec 24, 2004 | 11:57 PM
Wyckedcamaro's Avatar
yeah unless you are running N20.
If you run the deadly gas called N02 you are sooo screwed.. Your motor will break the motor-mounts.. pop out of the hood.. look you dead in the face while you are in the drivers seat.. and then spit a rod at you!
BUT! If you run N20 you will be fine.
Old Dec 25, 2004 | 12:34 AM
JPJBC's Avatar
LMAO
Old Dec 25, 2004 | 08:12 AM
BMN's Avatar
BMN
No, as long as you don't try and get greedy and spray a bajillion HP shot. Keep it at a safe 100 - 150 HP shot and you will never be happier. Make sure you buy a window switch. This is a very important saftey piece. It will protect your motor by turning the nitrous on and off at certain RPM levels. Got to the link in my sig and find the FAQ section to learn a little more about them.
Also, do yourself a big favor and call Nitro Dave's. Tell him what you are looking to do and they will set you up. They are gone till Jan 3rd. 1-866-648-7637.
