Need some Diagrams HELP?!?!?!
Old Dec 27, 2004 | 10:06 AM
Ravenous T\A's Avatar
Question Need some Diagrams HELP?!?!?!
I need a diagram for a MSD Window Switch, FPSS hook up to a Cold Fusion Nitrous Wet kit. I need to double check everything. I tried it this weekend without any pills in the Box and N20 Shut-off and my Noids didnt fire???? The relay on the CFNS kit has wire to 12vlt source, wire to noids, ground wire, and wire to WOT switch. I have a NOS adjustable FPSS too ( havent adjusted it yet, still on factory setting from NOS)
Old Dec 27, 2004 | 10:18 AM
David@TNT's Avatar
We have a basic diagram, http://www.texasnitroustechnology.co...structions.pdf hope it will help ya out...
Old Dec 27, 2004 | 01:28 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
You will wire the system up as per your standard instructions with one exception. The fuel safety and the window switch. Connect your relays ground wire to one terminal of the FPSS, the other terminal will go to your window switches yellow wire.
On the window switch black is ground, red is key hot or arm hot, white is tach.
Send me your email address and I will forward you the drawing.
Ricky
Old Dec 27, 2004 | 04:03 PM
gtx505hp@aol.com
the TNT instructions look like the perfect way to do it. Is it right for my kit????
