what should I turn on/off at?
Old Dec 27, 2004 | 12:50 PM
ccajun4real's Avatar
Default what should I turn on/off at?
I have an SS3600 TC and my rev limiter on my A4 is set at 6300 RPM.
What should I turn on at and what should I turn off at for max gains in the 1/4 mile?
Cajun
Old Dec 27, 2004 | 01:07 PM
GM Muscle's Avatar
With me it depends on how the track is hooking. If it's hooking good, I'll set the "ON" a couple hundred RPM under the stall so it hits dead out of the hole. If the track is hooking just ok then I'll set it about 500rpm after the stall so I can get the car out of the hole before it hits. Since your trans is built I would spray right through the shift and put the off about 200 rpm before the limiter.
Old Dec 27, 2004 | 01:16 PM
So if I can hook it I should set ON at around 3400 RPM and off at 6100 RPM. Thanks for the help bro
Cajun
Old Dec 27, 2004 | 03:33 PM
GM Muscle's Avatar
Yeah, I think that would be a good start.
Old Dec 27, 2004 | 06:55 PM
Ed Blown Vert's Avatar
Sounds like a good starting point.
Old Dec 29, 2004 | 06:33 AM
mike c.'s Avatar
i start mine at 3,000rpm's and shut her down at 6,600rpm's right at my shift point. i was shutting down at 6,200 but now at 6,600 i gained another 2 tenths.
Old Dec 29, 2004 | 09:44 AM
777's Avatar
777
dang that is a big difference for 400rpms
Old Dec 29, 2004 | 09:51 AM
Debian Dog's Avatar
Off???
