How much money?
Old Dec 28, 2004 | 11:04 AM
777's Avatar
777
Default How much money?
How much money will it cost to run a 100 shot on a full bolt-on ls1...everything i need....including fuel...i don't know whether i would want dry or wet either...i suppose i'll need a window switch...is harlan's good...i'm completly new at nitrous...so i need all the help i can get...thanks
Old Dec 28, 2004 | 11:10 AM
Magic Chicken's Avatar
12 Second Truck Club
Call nitro dave, he can hook you up with everything for a great price.
www.nitrodaves.com
Old Dec 28, 2004 | 11:16 AM
777's Avatar
777
yeah actually my girlfriends brother-in-law has a shop in kentucky i think he will be able to hook me up real good...i just haven't had the chance to talk to him abou this...so i was trying to get opinions from here first
Old Dec 28, 2004 | 11:41 AM
GM Muscle's Avatar
For a quality wet kit done right start to finish I would budget around $1000. It's the small stuff that ads up, like purge, heater and things like that.
Old Dec 28, 2004 | 12:48 PM
777's Avatar
777
what's safe shot i can run...100-150-??? i want it to be SAFE...no problems whatsoever...also how much does it cost to fill the bottle?
Old Dec 28, 2004 | 01:27 PM
iamsickofitall's Avatar
with a stock fuel pump and injectors, 150 is pushing it on a dry kit...100 shot will be fine on a stock setup going dry...if you want total peace of mind, get a fuel pressure safety switch with your dry kit in addition to the window switch and WOT switch...it can come right off the fuel rail and if your pressure drops too low, the system stops spraying...a lot of guys will tell you that you can get away with not having the FPSS if you start spraying at or above 3000 rpm at WOT with a 100 shot or so
there was a big thread a while back with n2o prices...you can probably find a local guy with prices if you can find the thread
Old Dec 28, 2004 | 02:00 PM
777's Avatar
777
thanks...i'll try and find it
