Nitrous Question
Old Jan 4, 2005 | 11:32 AM
bottlefed5.0's Avatar
Default Nitrous Question
I need some oppinions. I'm not sure what I should pill the N20 at. I changed the tires(to Drag Radials),31 spline axles, axle girdle,and installed a spool last night. It's a C4(3 speed) reverse manual valve body, 4000 stall w/trans break wired up when you disengage the T/B the nitrous comes on. What should I pill the N20 at? Oh yeah, it in a Mustang. ( sorry )
Old Jan 4, 2005 | 11:57 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
200hp to start with. Hold on
Ricky
Old Jan 4, 2005 | 11:58 AM
TApimp's Avatar
Whats the motor setup? Fuel system? Carbed or injected? Direct port or plate? so many questions
Old Jan 4, 2005 | 11:59 AM
Ricky
Do you think the BFG Drag Radials will hook up though?
Old Jan 4, 2005 | 12:06 PM
I'm not worried about the motor, I'm worried about getting the car to hook up.
Old Jan 4, 2005 | 05:46 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
I do not think it will hook with a large shot! You might want to look into a DynoTune Time delay switch so you can get out of the hole clean and after a set time it will kick in. this will allow you to grab traction and dial in the perfect launch!
Check it out here...
http://www.speedshop.org/store/Scrip...?idproduct=107
