forged or not
Old Jan 11, 2005 | 05:20 AM
xcobra's Avatar
Default forged or not
I always thought to run nitrous in a car you needed to have forged rods and pistons. I dont think ive herd one person with forged parts yet. So how safely can I run a 100-150 shot well tuned on an ls1. How about the life expectancy once I begin to run nitrous. Thanks for any opinions.
Old Jan 11, 2005 | 05:49 AM
CAT3's Avatar
Restricted User
With the right **** you can be safe. I have run loads of 150, bottles of 75 & 100, a cylinder or more of 175 shots and a few 200's, not an issue here. I spray out of the hole and thru shifts. I dont recommend to do that for the trans sake, but I do it = lazy. Using the right plug, tune and jetting 100, 150 is easy. Depending on prior mods, may need a fuel pump upgrade too. I use the Walbro 340 intank. Now if I had forged internals, I'd be spraying a helluva lot more than 200 thats for sure.
Hope this helps and good luck.
Charlie
Old Jan 11, 2005 | 08:13 AM
next's Avatar
There are definitely a lot of forged setups out there, it's just those guys don't have to put a disclaimer of "stock" stuff.
Charlie said it well, focus on tune and fuel and you should be fine.
Old Jan 11, 2005 | 08:17 AM
Big Mike's Avatar
You can never go wrong with forged. It helps you sleep better at night!
Old Jan 11, 2005 | 09:15 AM
LOnSLO's Avatar
Amen brother! Knowing your shortblock will hold a 500 shot or more is very comforting.
Old Jan 11, 2005 | 03:56 PM
GM Muscle's Avatar
Mike hit the nail on the head. I've had several nights where I went to bed thinking, was that hickup I felt today a motor issue or, the car laid down in the top of 3rd and I hope it was just a pressure issue and not a motor issue, and of course the famous, **** I burnt a plug, what's my compression test going to look like tommorow.
Seriously though, I've beaten the **** out of this stock long block for 2.5 years now and it's still going strong. I can't even fathom how much nitrous I've put through it. I have a refill station here at the house and I usually have to top the bottle off every other day or so in the summer. With a good tune you should do ok with the stock bottom end. Most of the time I run a 150rwhp shot and have played around with a 200rwhp shot on the street. At this point I'm really thinking of spraying a 2 stage 250 shot (at the crank) next year.
