Single NX Shark Nozzle
Old Jan 15, 2005 | 01:04 AM
Nine Finger 02 Z28's Avatar
Default Single NX Shark Nozzle
I am building my car for a class and I am only allowed a single nozzle.So I was wondering what the limits are of this Nozzle.It is going on a 408.And the main line is -6.
Old Jan 15, 2005 | 09:53 AM
Bad30th's Avatar
I'd call NX directly or PM Ricky. I know it will pill up to at least a 150 shot, not sure what it will flow with no pill on the n2o side. 200 maybe ?
Also just a thought, I wonder if a machine shop could enlarge the internal nozzle passages for higher flow - still a single nozzle, right ?
Bad30th
Old Jan 15, 2005 | 10:08 AM
Green Thunder's Avatar
I believe shark nozzles are good for 250hp
Old Jan 15, 2005 | 10:18 AM
BTL FED's Avatar
If you are limited to a single nozzle run the NX SHO Nozzle, they are adjustable from 35-400 horse
http://www.nitrousexpress.com/Catalog/2005/sho.pdf
Old Jan 16, 2005 | 10:50 PM
Nitro Dave's Nitrous Outlet's Avatar
Correct,We have alot of customers running classes like this.The SHO Nozzle is what they are running.It will flow 400 hp.If you need any help shoot me a pm.
Dave
Old Jan 17, 2005 | 09:05 AM
NXRICKY's Avatar
Closed ex-Sponsor Account
The SHO nozzle will flow 400 hp. You also need to change the nitrous line going from the nozzle to the solenoid. It is a -4 line with one end having a -3 nut for the nozzle and the other end is -4 for the solenoid fitting.
Ricky
