NX MAF kit with a 90mm TB/Intake
Old Jan 28, 2005 | 10:13 AM
93LS1RX7's Avatar
Default NX MAF kit with a 90mm TB/Intake
Is it possible? Is it going to reduce the airflow dramatically? I have heard the stock MAF diameter is maxed out at around 1000cfm which is more than enough for most every motor but I dont want to restrict at all if necessary. Does NX offer anything that can mate to the 85mm MAF sensor from the vette?
Old Jan 28, 2005 | 10:18 AM
Hawkn01's Avatar
I beleive Nasty Nate sells that item for the 90mm TB.
Old Jan 28, 2005 | 10:55 AM
Elite_Hot_Rod's Avatar
I run the NX MAF kit with the stock MAF sensor and the 90MM T/B and intake, it seems to do pretty well. I don't know if you could even tell a difference between an 85 MM MAF and the stock 78MM MAF.
Old Jan 28, 2005 | 10:58 AM
Beast96Z's Avatar
Sell the MAF plates, get you a 85mm mass air, then get the 90mm coupler from Nitro Dave.
Old Jan 28, 2005 | 11:12 AM
Hawkn01's Avatar
Ah, ok I was wrong. Nitro dave is what I should have said.
Old Jan 28, 2005 | 11:51 AM
93LS1RX7's Avatar
I guess the other question is does the 7mm make any difference?
Old Jan 28, 2005 | 12:14 PM
I guess theoretically the 78MM air box would be a restriction and make a difference but in real life I don't think it does, I don't use an air filter if that makes any difference.
