-7 plugs for nitrous
Old Jan 31, 2005 | 10:15 AM
LOnSLO's Avatar
Originally Posted by V6 Bird
I dont consider mine leaner...I start the AF at say 12.5 at 2500 and lean it out progressively till peak HP then leave it at 12.9-13.0:1 at peak HP NA. Cruise around town is about 15:1
Mike
That's not bad at all. I may run an experiment in a couple of weeks.
V6 Bird's Avatar
Originally Posted by white2001s10
The way I look at it, blasting N2O into your engine isn't what I'd call safe in the first place. I spray to push the limits of the engine and see how much power output I can get and it still hold together... not a very safe thing to do.
Tuning the N2O leaner will indeed get more power, so that is the purpose of running the cold plugs.
That's what I do because I have no intention of doing what's safe for the engine. I just want to avoid major engine damage due to a stupid plug failure. I'd rather see something else break besides something due to a plug failure... that's just me.
I've never cared for running any resistor-type plug while spraying, so a lot of those plugs you are talking about, I'd never even try myself.
Pretty much the same way I look at it. I like to push the envelope myself too. But I also like to keep the car consistent as well. I always double check pressure in the bottle, how many passes ive made, tire pressure after a burnout, etc. I want to go fast, but at the same time I dont want my ET's being more then a .1 difference either.
Old Jan 31, 2005 | 10:22 AM
LOnSLO's Avatar
Non-resistor type plugs and GM pcms don't get along too well in my experience. I still recommend the number 7 NGK for Phillip. I see what you're saying by wanting to avoid engine damage. If that is what's working for you, then go for it. I have had much success running the hottest plug I can and not pre-igniting.
Old Jan 31, 2005 | 10:27 AM
V6 Bird's Avatar
Good luck with it...Ive not had that success in many cars. Thats why I dont recommend TR anything.
Old Feb 1, 2005 | 01:47 AM
verbs's Avatar
I'm running the #7 Iridium plug from NGK and it works great so far. No problems. I know others running em w/o any problems and we're both running big shots of over 200.
Old Feb 1, 2005 | 12:48 PM
V6 Bird's Avatar
I'll stick to copper but thanks for the heads up.
Mike
