spraying with an m6
Old Jan 29, 2005 | 01:34 PM
smokin t/a 600's Avatar
Default spraying with an m6
What is the best way to setup a n20 kit for a m6 car, any tips or things that you should watch for when your using it?
Old Jan 29, 2005 | 01:50 PM
OneMeanZ's Avatar
Get an NX or TNT kit, bottle warmer, purge, etc. A window switch and I'm sure I'm forgetting things....
Old Jan 29, 2005 | 06:29 PM
Robert56's Avatar
Depending on what tire/gear your running, you may want to consider a first gear lock out. That's what I am doing because I go up in smoke and am trying to get a dead hook (without leaving the vette rear scattered). Allthough the Z06 has lower 1st and 2nd gear and more power to start with, a N20 kit wet or dry can make launches on any car, tuff. Oh yea, a FPSS or fuel press safety switch would be a good addition.
Old Jan 29, 2005 | 06:55 PM
coop5885's Avatar
please buy a WINOW SWICTH. it will save your car. I know mine has before. All it takes is one missed shift and the sh$t can hit the fan. I have mine set up on a window switch and a WOT swicth. Worked great for me so far. Now all i need is traction.
Old Jan 29, 2005 | 07:33 PM
BMN's Avatar
BMN
Ditto! Worth their weight in gold.
Old Jan 29, 2005 | 07:37 PM
DynotuneN2O's Avatar
LS1TECH Sponsor
A time delay switch can help with traction as well. If you shift to fast the nitrous is gonna kick in to quick.
