Best Off-Shelf Nitrous cam??
Mods in my sig.
If you want a nitrous friendlier grind stick to the 114 and up LSA grinds. You need to also take into account the valve events. Less overlap is good on the squeeze.
Cylinder pressure=power
Cylinder pressure=heat
With heat you need more fuel and cooler plugs to keep things in check.
