Building custom dry kit need some help??
Old Feb 11, 2005 | 02:57 PM
BTLFEDSS's Avatar
Default Building custom dry kit need some help??
I am building a custom dry kit as stated above her are the parts i have
10lb bottle
16ft feed line
solenoid
2ft 4an line
w.o.t switch
window switch
fpss
Now where can i get a dry nossle to go into my lid and jets anyone help???????
Thanks BTLFEDSS
Old Feb 11, 2005 | 03:05 PM
GM Muscle's Avatar
NOS makes both straight jet style dry nozzles (like the ones that come with the 5177), and a really nice 90* fan spary nozzle. The jet style would probrably work best in the lid but you could probrably make the 90* work depending on where you mounted it. I'm not positive but I think that the NOS nozzles are only made for a -3AN connection.
Old Feb 11, 2005 | 05:01 PM
SlowGreenTA's Avatar
You may talk to nitro dave here on the board about what you still need.
Josh
Old Feb 11, 2005 | 10:08 PM
Neolloyo's Avatar
As weird as it sounds ...... When I put a dry kit in my toyota truck ( which I do not have any more ) I found some of little odds and ends for the kits on www.Nopi.com and then go to the electronic catalog I think it says.
Old Feb 11, 2005 | 10:17 PM
Robert56's Avatar
What's Nopi.rice anyway?
Oh yea, welcome aboard.
Old Feb 12, 2005 | 06:24 PM
BTLFEDSS's Avatar
Would any thing else be needed in tapping the nozzle in to the lid for support or strength or can i just tap in to it??
BTLFEDSS
Old Feb 13, 2005 | 08:23 AM
GM Muscle's Avatar
I'd put a nut on the inside of the lid to hold the nozzle tight. You might need a nut on the outside too depending on what nozzle you go with.
Old Feb 13, 2005 | 08:41 AM
DynotuneN2O's Avatar
LS1TECH Sponsor
BTLFEDSS,
This may help you out
http://www.speedshop.org/store/scrip...?idproduct=111
Dean
Old Feb 13, 2005 | 08:44 AM
GM Muscle's Avatar
Dean, I was looking at those myself. Do all nozzles have the same size thread and pitch? Basicly, will it work with an NOS dry nozzle.
Old Feb 13, 2005 | 09:10 AM
LS1TECH Sponsor
Should work with all nozzles with a 1/16 npt thread. The NOS dry nozzle will work as will most of the nozzles on the market. There are some nozzles on the market with a larger thread and they will not work but most are the standard 1/16"
Hope this helps!
Dean
Old Feb 13, 2005 | 09:19 AM
BTLFEDSS's Avatar
Thats what i thought i needed good deal you guys are close to me should be completeing kit shortly maybe from there to a dual stage
BTLFEDSS
Old Feb 14, 2005 | 05:07 AM
OnE Ls1 2 HaTe's Avatar
so if i have an nx shark nozzle wet kit and going dry which fitting would i need to make it into a dry shot using a nos fan nozzle
Old Feb 14, 2005 | 06:24 AM
GM Muscle's Avatar
You'd want to replace the shark nozzle with something like this. They are about $15.
Jet spray
Fan spray
Old Feb 14, 2005 | 10:57 AM
BTLFEDSS's Avatar
I am goting with a fan spray found them for 12.99 and 4.99 for jets
BTLFEDSS
Old Feb 14, 2005 | 01:10 PM
BTLFEDSS's Avatar
Can get a 4ft piece of 4an line to run noids to the nozzle if i can would that be to far of a distance between the 2??Want make it completely hiden
BTLFEDSS
Old Feb 14, 2005 | 02:56 PM
GM Muscle's Avatar
I think those nozzles use -3AN connection. I would wait to get the nozzle before you get the line or a reducer. On a dry kit I don't think 4ft of line between the noid and nozzle is a real big deal.
Old Feb 14, 2005 | 04:41 PM
BTLFEDSS's Avatar
Sweet yeah i think they are 3an too going to hide all the noids near foglights purge out of the foglight opening and spray from under the lid and hide window switch near the fuses whata think
BTLFEDSS
Old Feb 14, 2005 | 05:51 PM
GM Muscle's Avatar
Yep, I can see it now. "What nitrous system?!....I only have a lid and cat back".
Old Feb 14, 2005 | 08:13 PM
BTLFEDSS's Avatar
BTLFEDSS
Old Feb 15, 2005 | 04:55 AM
what about in the air tube that goes into an slp lid?
