N X problem please help
Old Feb 15, 2005 | 06:55 AM
smokeum99ta's Avatar
Default N X problem please help
The red sealant/locktight supplied with N X kits.I put every thing together years ago.Then maybe a week later I got the purge/heater/etc. Now Im servicing the noids with the new tool I got from N X and cant get the fittings loose with the red s--t on them.Anyways to make a long story short I plugged the purge on the N2o noid with the supplied plug and red stuff before I purchased the purge kit. I'd like to use hole in the noid for the purge but I cant get the plug out.Whats the secret for getting this loose,Im just twisting the allen wrench up.Heat,wd40,or something else?Im not trying to buy a new one due to me damaging the one I have.
Old Feb 15, 2005 | 07:17 AM
30thz's Avatar
apply a little heat, only as much as needed to loosen the plug or fitting. I use a little pen torch long enough to loosen the locktite.
Old Feb 15, 2005 | 07:38 AM
I dont have any access to a pen torch.I have a oxygen/accentalen torch on my welding rig but it has a big tip on it.Im afraid that it might burn something else on the noid.What about a cigarent lighter?
Old Feb 15, 2005 | 07:59 AM
Alright I couldnt wait any more for other bright idea.I got it loose using my torch of my truck. Thanks anyway 30thz. Hope I does fuc- anything up.
Old Feb 15, 2005 | 08:01 AM
HAMRHEAD's Avatar
use a small propane torch. They're cheap and adjustable.
Old Feb 15, 2005 | 08:02 AM
HAMRHEAD's Avatar
Plus you'll more than likely need it for something in the future anyways. I did!
